Resolved Slow coolant leak dripping from passenger side frame rail.
Doing pressure test as I type this so for no leaks...set at 16lbs
20 minutes and the gauge has not moved off 16lbs mark No leaking under the framerail.
Hallelujah you got a tester going! :nice::rock:Now leave it pumped up overnight. (Or at least several hours.)
I had the same clamp that needed tightened one of the last times I used the tester. When the car was running, the heat and airflow hid the drip. But cold pressure testing made it obvious.
Its been 24 hours and no leaks so all it was is the left heater core hose clamp was loose.
