thank you..... I watched a few youtube videos where they used it ......I use synthetic brake caliper grease.
Anti-seize shouldn't be used anywhere where it will get wet. The anti-sieze itself contains bits of metals that when exposed to moisture can induce corrosion. Not saying this will happen every time, but the potential is there. There is a specific anti-seize designed for wet areas.
Use the grease there as well.thank you..... I watched a few youtube videos where they used it ......
different topic, but we used to use an anti squeal liquid on the back of the pads, usually on the pad pushed by the pistons..... It actually had a picture of a pig on it and it was pink..... applied some, let it dry and no squeal..... Is this still used? or is the Brake caliper grease used for this area also??
Thanks.... I did see where some newer stuff ( Copper colored) is now being made, wondered if it worked better? The old silver colored stuff NEVER comes off where you didn't want to apply it....Short answer is yes, I do and have been for several decades now with no issues. I use the silver colored stuff sold at napa in a container with a screw on lid that has the brush attached. One can of that lasts me a long time. Good stuff.
You may also like this then. It may be similar to what you posted, with both being a synthetic brake system grease.....but it is "ceramic-fortified" (their description), for higher temperature resistance. I've never had any problems with it.![]()
Sta-Lube Synthetic Brake & Caliper Grease
Sta-Lube Synthetic Brake & Caliper Grease is a high temperature synthetic grease safe for plastic and rubber. Resists moisture and will not washout.www.crcindustries.com
I have literally put that on thousands of cars ( @90sickfox probably has too). It's what Carmax uses on ALL brake jobs and brake inspections (or at least it was from 2016-2020 when I worked there).
It works.
Been working on cars professionally for over 40 years. I have never used any grease on the pads or anywhere else. I will lube the caliper guide pins that go into the caliper bracket. But otherwise everything is clean and dry. I also never have any comebacks for brake squeak or noise.
Currently GM has Bulletins for replacing pads on several vehicles for brake noise, but that is a quality control problem on GM's side, not a install issue.
What does grease or any lubricant do? It collects dirt, dust and anything else that touches it's surface. What does that dirt, dust and what not do? It causes wear, and noise. Put it together clean and dry and chances are it will stay clean and dry. Al least it won't become a grimy mess.
