Progress Thread Snow - 93 GT Vert. Prepping for sale
Well,alot of folks online are dumb. Your SFCs will cradle nicely in the notch on your jackstands. They make "sleeves" that go on the stands that won't scratch your SFCs if you're worried about that.
Def not worried about scratches. One video showed indentations on original subframe from stands. They recommended the wood, so went with it.
Next time it sounds like I don’t need to worry about it. Thanks :)
Anyone know where to get these plastic clip things?
Brace the intake with the tb opening facing up, spray PBBlaster or equivalent on the studs that are left and the holes of the removed studs, also around the base of the egr spacer, let it set over night. Tap the spacer with a hammer a few times and spray again, tap, spray repeat a few times throughout the day, a good metal scraper tapped between the spacer and intake can help too.
Reactions: JAA
