hey guys, really stumped on this one. 91 gt 5.0
A little backstory, my car caught on fire from the battery. I replaced everything that was damaged, wiring etc. the ecm than had an issue that the fuel pump wouldn't kick on unless jumped so I sent out the ECM to get repaired. it came back and had a new issue where it would crank on the quarter turn so I sent it back and it came back still not fixed. So I decided just to buy a new one. I bought a mega squirt with the base 5.0 maps, I put it in, ran the vacuum line and it worked great besides not being able to idle without some throttle. As i was figuring that out I go to turn it on and then all of sudden it cranks great but no spark. If I take out the spout that disconnects the computer it does have spark. it gets fuel and everything else work's. I than put the old ECM back in and it has spark when I turn the key and it cranks. So my conclusion is somehow the new ECM went bad? I'm stumped really any help is appreciated
but, still able to fire if the base timing is right and most of the injectors are firing.
