Thank you for this.So if it were me I would stud the lower intake. They pull down better and you are not turning a bolt into aluminum threads while pulling up on the threads. With the studs you are turning a nut on the top of the stud that is in turn pulling upwards on the threads at the bottom of the stud with no turning. Witt that they will have way less of a chance to strip the aluminum threads in the heads and the compression on the gasket is a lot better.
I got the studs for both of mine at O'Reillys (believe they were Dorman) and had to thread the upper part farther down the stud as there were not enough threads. If I were to do it again I would get the ARP 354-2103 intake studs. My enginer builder had me ditch the regular washers and get 5/16" plain finish williams washers.
Amazon product ASIN B005ASZ1HO
View: https://www.amazon.com/ARP-354-2103-Intake-Small-Block/dp/B005ASZ1HO/ref=sr_1_1?crid=L9Y51MTZE7KL&keywords=arp+354-2103&qid=1684371291&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&s=automotive&sprefix=arp+354-2103%2Cautomotive%2C117&sr=1-1&ufe=app_do%3Aamzn1.fos.006c50ae-5d4c-4777-9bc0-4513d670b6bc
Not saying this is cheap by any means but after I stripped a couple of the intake threads on my AFR185's it would have been money well spent.
Stole this from a post by jrichker:
The bolts are torqued down in a 3 step process.
Step 1 8 ft/lbs
Step 2 16 ft/lbs
Step 3 23-25 ft/lbs
Done. And chased all head holesMy upper intake is completely studded as well. Hell my TB and TB spacer are studded to the upper intake.
The torque specs apply to basically every lower intake that I know of and even the carbureted intakes. Same values and sequence that I use the on Vic Jr on my T-bird with the 351W.
Be sure to clean out the injector bosses. Mine are bare metal as I feel like that gives the o-rings a better chance to seal. Lube the o-rings with some light weight oil prior to installing as that will keep them from cutting or tearing.
Got the replacement pintle cap stuff.No plastic seals. Just a big bead of RTV sealant, let it sit for about 15-20 min and then put the lower on.
The plastic "caps" are called pintle caps and you can get them at most parts stores:
Vacuum line routing for an Explorer intake:
Engine - Explorer intake vacuum line diagram
Have seen this question asked a million times. So here's a diagram. This is an EARLY Explorer intake with the EGR port. There were two lower manifolds. The RF-F87E-9K461-BA lower was early and had the bosses present for the ACT. The RF-F87E-9K461-BB lower was later (non-EGR) and lacks the...stangnet.com
Reminds me of when my EX friend who owned Two Guards red 911 Porsches, called me to drive one home from town for him.... Yup, I sure could....Sorry for the late response got a call from a buddy to ride shotgun in his 69 fastback to a parking lot full of bad ass cars last night at the local AutoZone.
I always use those rubber ends,never had a problem with them.
