7.5" vs 8.8" drum brake compatibility
philcore3
Aug 20, 2004
43
I have an 85 which i am restoring, I debated back and forth between keeping the 7.5" axle or swapping out to an 8.8". In the end, due to budget and simplicity I decided to keep the 7.5 for now. My question is, when shopping for new backing plates, are the 7.5 and the 8.8 the same part? I already verified that my new axles and drums fit 79-93 so I'm 75% sure that back plates are the same but want to make sure. Thanks!
My understanding is they are different and UNAVAILABLE..... I have had offers for the backing plates from my 7.5 I removed who have told me this....
Reactions: 85GTStangGuy
All of the drum brake components are the same between 7.5" and 8.8", on the Mustang...backing plate, drum, shoes, wheel cylinders, etc.
10" rear drum brakes were OE on V8 LTD/Marquis, and maybe Fairmont/Zephyr wagon? (I don't remember exactly other than LTD/Marquis.) They were not ever on Capri/Mustang so that LRS kit is an 'upgrade' and would require parts in that kit (larger diameter backing plates, large diameter drums, large shoes, etc.).
  • Useful
Reactions: General karthief
I did the cobra brake upgrade and have the backing plates and e brake cables . Lmk.
Reactions: limp
Don't some of the 7.5" come with 9" drums?
They all did. Same as all the 8.8s... 9" drums also. That's what FoxChasis is saying.... that the 10 inchers were only on V8 LTD's and Marquis' (and maybe F/Z's).... never on Stangs or Capris.
Reactions: limp
I have used 82 rear 7.5 brakes on both 7.5 and 8.8 axles. I usually remove the axles, unbolt the backing plates, leave the lines connected and just put it all back. May have to tinker with the axle vent and hard line, but easy.
So if you have 9" 7.5 backing plates and you are running 10" drums, will the smaller backing plates work??
I think Rangers got the 10" drums as well.
But my understanding was the same about the 7.5" and 8.8 drums. They are the same 9" units. Even the axle shafts are the same. You could take a 7,5" with drum brakes and swap them onto an 8.8 housing and use everything.
EDIT: However, i typically think of 86+ when I say this. The early 4-eye cars got some weird parts. There were aluminum drums, 9" front brakes, and even a 6.75" sterling axle. There was even a weird German 5-spd trans that nobody knows about.
Aluminum drums were on early (before 1983) turbo cars. If they happened to make it onto turbo cars before 1983, so be it. Same years for 9" front disc and 6.75" rear axle .. but they were for non-V8 and non-turbo cars.
The 5-speed, which was NOT a T-5, was made by Tremec in Mexico, and dated back to late 1980 model year and went through the end of 1983 model year. (So there were TWO 5-speeds in model year 1983 but almost no one knows about the Tremec 140VS 5-speed). The German transmission was a 4-speed and was used through 1986.
Fox Capri/Mustang manual transmissions:
Ford of Germany (FoG) nnET 4-speed (trans tag "78ET" or "83ET" and "FOG", door tag "7")
Borg Warner 4-speed (trans tag "RAD", door tag "6")
Tremec SROD 4-speed overdrive (trans tag "RUG", door tag "5" 1979 and "4" 1980-83)
Tremec 140VS 5-speed overdrive (trans tag "RAP", door tag "5")
Borg Warner T-5 5-speed overdrive (trans tag "13-52", door tag "2") --- Borg Warner sold manual transmission division to Tremec in 1998
