For the fuel lines at the engine I wanted to clean up the Vortech FMU lines. The kit left the factory engine hard lines in place and connected at the return line connection down by the sway bar. The power pipe was rubbing hard on the steel pressure line and Schrader valve. I also wanted a good spot to mount my fuel pressure sender for the guage.
I used the parts from a Russell foxbody AN fuel line kit. For the pressure line from the fuel rail to the plastic line at the sway bar I used the line in the kit. The only modification was adding a Earl's tee for the fuel line guage and trimming the braided line a bit. Tee is part # EAR-AT100199ERL.
For the return line I used the 2 quick connect fittings from the Russell kit to connect the Vortech line to the fuel rail. This way I could go from the fuel rail to the FMU and then form the FMU to the connection at the sway bar eliminating the hard line. It's a lot cleaner than before. The only addition fitting I needed was a -6AN union to go between the 2 Russell quick connects at the fuel rail. Part # AT91506ERL.
The FMU Fittings are SAE, which look pretty close to AN, will thread together, but aren't compatible and will leak. Different shoulder angle. That's why I couldn't just run the Russell line from the rail to the FMU.
This really helped with fuel line clearance on the power pipe.
