I found this 1993 LX 5.0 5spd while "window shopping" online. The motor was recently rebuilt and has less than 500 miles on it (overall mileage is unknown for the chassis). The owner had done a ton work on it already and was looking to move on to another project. The paint has some blemishes but all in all not too bad. There is a little rust along the top of the hatch and sunroof but I'll be looking to have the car ready for a new paint job in the next year or two so that shouldn't be too much of a concern right now. The price was reasonable given the amount of work had been done so after talking with the owner and driving up to see it, I pulled the trigger and brought it home yesterday.
The car runs strong although I'm not sold on the "F" cam and 4.10 gears just yet. I'm not sure how "street-able" its going to be but I'll run them for a bit and see how I feel.
The first order of business will be getting some new wheels/tires. I've got a set of 16' Pony's in the garage that need some paint and some new rubber (maybe a 245/50/16 all the way around) so I'll probably swap over to those in the next couple of weeks. I'll have to adjust the speedometer gear that point but right now the speedo isn't working so I need to look at it anyway.
Once that's squared away, I'm going to start cleaning up the motor. It needs a some TLC, elbow grease and paint. I'll have to look at the best way to paint things like the intake as it's looking pretty rough right now.
I also need to replace the dump tailpipes and get some 2.5" LX style pipes to come out the back. It's an iconic look and right now things look "funky" without them there.
List of upgrades:
Under Hood:
Rebuilt A9L computer
Line lock
Brake lines
new master & wheels cylinder
Motor mounts
Starter Solenoid
Replaced all hoses
Camber Castor plates
Front and Rear end:
8:8 rear end rebuilt
4:10 Ford Motorsports
Spherical upper housing bearings
Upper and Lower Control arms
Seals
pinion & cover
Long Wheel studs front & rear
Urethane rear spring isolators
Urethane front sway bar bushing
Body & under carriage:
Front Struts
Rear shocks
340 LPH fuel pump Welbro
X-pipe & Flowmaster super 40 exhaust
Tires 275/60/15 & 215/60/15
Welds (4) 8x15.
Interior:
Front & rear carpets & hatch area
Headliner
Shifter boot kit
Door hinge kit
Door seal kit
Hatch seal kit
Sunroof seal kit, body & hatch
Sunroof retaining clips
5 speed clutch brake pedals
Stereo
Rubber clutch & brake pad
Fuel filter neck grommet
Mirror hole cover kit.
Motor & Transmission components:
King cam bearings
Clevite main & rod bearings
Speed Pro rings
Melling’s high volume oil pump
SVT oil pump shaft
Cloyes double roller timing chain
Fel-Pro full gasket set w/one piece oil pan gasket
GT40 heads (ported)
ARP head bolts/560 lift springs (Alex Springs)
GT40 Explorer upper and lower intake
MAC 70 mm throttle body
MAC cold air intake w/ 75 mm MAF sensor
Ford Motorsports “F” cam
MAC ceramic shorty headers
Ford Motor Sports 8 mm plug wires
Alum high flow radiator
Water pump
SN95 alternator conversion
Mini starter
50 oz. pressure plate
Center Force stage 2 pressure plate & clutch
ARP pressure plate bolts
T5 rebuilt w/ Pro 5.0 shifter base
Pictures
Obligatory Trailer Picture
Front
Driver's Side
Rear
Passenger Side
Engine
List of upgrades:
Under Hood:
Line lock
Brake lines
Motor mounts
Starter Solenoid
Replaced all hoses
Front and Rear end:
Seals
pinion & cover
Front Struts
Rear shocks
Welds (4) 8x15.
Interior:
Headliner
Shifter boot kit
Door hinge kit
Door seal kit
Hatch seal kit
Stereo
King cam bearings
Speed Pro rings
SVT oil pump shaft
GT40 heads (ported)
Water pump
Mini starter
Pictures
Front
Driver's Side
Rear
Passenger Side
Engine
