So the car sat for about a year and ran perfectly fine when I parked it. Finally got back around to working on it and when I went to start it it wouldn’t start. I replaced the battery, battery cables, ignition coil, distributor cap, rotor, and the TFI module. It has 36-39 psi fuel pressure at the schrader valve, it has spark, I can hear the fuel pump running when I turn key on, and there was no light or pulse when tested with noid light. I’m stuck and don’t know where to check next.
