Starts with starter fluid then dies
I have a 1985 foxbody 5.0 HO with a Edlebrock 650 carb. Recently changed out my ignition control module and distributor cap and I removed my smog pump. I believe I do have some vacuum issues. Also will not turn over unless I use Pyroil (started fluid) it will idle immediately to about 1500rpm and die even if I try to give it a little gas it dies.. I'm completely lost as is it a wiring issue somewhere, is it a vacuum leak. Please help
So you said you have a mechanical fuel pump and then you said you here the pump come on when you turn the key on? So is the pump electric or a mechanical unit on the side of the timing chain cover?
It could be the sock filter in the tank is plugged.
So when I turn the key to the on position I hear the fuel pump make the sound that it's coming on
How can it be mechanical if you hear it come on when you turn the key on? The only way it is a mechanical pump if it is mounted on the side of the timing chain cover. Pictures would be very helpful here.
And could you explain sock filter to me as well please
Sock filter is in the tank on the pickup for the fuel pump. Looks like this:
1985 is the one year that the Mustangs came either carbureted or with CFI (central fuel injection). Carbed cars came with a mechanical fuel pump that physically mounts to the timing chain cover and is driven by an eccentric that is installed on the front of the camshaft timing gear. The CFI cars had two electric pumps. One low pressure pump in the tank and one high pressure pump mounted external to the tank.
Some folks removed the CFI and high pressure pump and used the low pressure pump to feed a carburetor.
@limp, can you post up a picture of the mechancial pump install on your '83?
I have an 85 sir with a 650 Edlebrock carb and yes it is mechanical that mounts on the side !
