I have a 1985 foxbody 5.0 HO with a Edlebrock 650 carb. Recently changed out my ignition control module and distributor cap and I removed my smog pump. I believe I do have some vacuum issues. Also will not turn over unless I use Pyroil (started fluid) it will idle immediately to about 1500rpm and die even if I try to give it a little gas it dies.. I'm completely lost as is it a wiring issue somewhere, is it a vacuum leak. Please help
