1970 Boss block
Sparky714
5 Year Member
Oct 16, 2015
382
213
73
North Dakota
I have an opportunity to buy a 1970 Boss block. I've been looking into buying or building a 347 for my '89 and a friend of a friend told me about this block he may be willing to sell. I don't have any details bore or anything yet, but I could get it for a decent price. Is it worth pursuing? Would all my accessories from my '89 302 bolt up to it? I'll still need heads, cam and maybe a different intake. And I'm guessing I'd need link bar lifters to run a hydraulic roller cam with this block? Or would I be better off sticking with my original plan of an assembled long block from Fordstroker or someplace with a newer block? Car is street/strip with a Vortech supercharger. Any advice appreciated.
From what I understand the Boss blocks are stronger than late model blocks, have more material in the webs, cylinder walls, etc, and had 4 bolt mains. And, as far as I understand again, they can take everything another earlier 302 block can. I think, if it were me and I was going to push the envelope, it may be worth looking into. I'd venture to say that it'd take more abuse than a standard block - probably somewhere in between a roller block and an aftermarket block. But I also agree that it'd be best suited for a 70 Boss Mustang and probably worth some money for someone looking to restore their car. I think I'd have to do some serious research and make a pros/cons list. :shrug:
Uh... That depends on price and condition, but if those two check out, hell yes it's a step up from a stock block. The problem is it's never gonna be a dart, man o' war, R302, or new boss block. It'd be like getting an A4. But it is still the best 302 block Ford ever put into a production car. I don't think you can go over 4.040 or so without a sonic check.
If it works out though, you can rev higher, and handle more power with that block, for sure.
Converting to roller is not a big deal. You'd just need link bar lifters. They're a few hundred bux. Factor that into your calculus.
Not huge power. I'd like to be around 600 wheel.
That's a perfect application for an intermediary block like a Boss 302. It's pushing a stock block pretty hard, especially if spinning over 6.5k, and would not push a Boss block at all.
The trick is making sure it's in good shape. The other trick is getting a good deal when it will always be worth more to someone trying to restore a Boss Mustang.
Well, you're right. They've gone up quite a bit in recent years, like everything has. Look up the Morel 7699 link bars. They're still going around $600 and will be going into my winter build. Not saying they're the cheapest, but at least cheaper than what you mentioned.
Looks like even stock hydraulic roller replacements would cost 170-260 from steeda depending on whether you want "high-performance."
Gotcha. Those are for "roller-capable" blocks though, right? The lifters I was looking at were the retrofit sets.... what I thought would be required for the OP's Boss block. Or I could just be confused. If so, then I blame it on having one too many (6-packs) today. :cheers:
Is Father Time your winter build?
  • PlusOne
Reactions: Noobz347
It seems that I read somewhere that you could use stock roller lifters in an older block by drilling/tapping for the retainer and just shimming it to the proper height?
  • PlusOne
Reactions: Mac131
I think you have it right.
Retrofit Style
Non Retrofit Style used to eliminate the dog bones from a roller block.
Reactions: 85GTStangGuy
This is for black jack on an, I hope, 350+ rwhp fuel-injected, stock-stroke, 2-bolt block, mild cam build.
Ed Curtis sold them to me. I think he knows what he's doing...
Father time is a completely different, but already finished motor. Only changes on it, this year, are a lower intake ported to match to AFR205s and an upgrade from a 76mm turbo to an 80mm.
Reactions: General karthief
