Progress Thread Komo's 1990 GT - Parts Gathering Purgatory
Searched around a little bit more. Called a different performance shop who doesn't do welding in house, but does work closely with a welder on automotive performance type things. They gave me his number and said he would do it for $600, so i might go that route. Maybe could get a little cheaper if i do the above 'prework' stuff @AeroCoupe mentioned.
Also, as i keep planning my 'build', and thinking about MAF/TB combos that are SMOG legal, are my options the 93 Cobra TB housing, and for MAFs i've been reading 94/95 MAF housings, or Cougar housings. Is there a thread that breaks this down i can search? It would be nice to keep it OEM 'looking', like parts with FORD stamped on them or whatever.
I keep thinking that$600 for subframe connectors welded in is way high.
I have a cousin Joe lives in San Diego ,haven't spoke in awhile but last I heard he restores cars ( he's got a five car garage on his proprty)
Ask around at car meets ,cars and coffee someone has to know a good welder that will do it fairly priced.
Its Joes garage in escodio?
Reactions: gkomo
Stock MAF thread here:
Reactions: gkomo
So something like this?
But will my Fox MAF sensor work in this housing? That thread talks about using a SN95 sensor. Or do I need this housing and also a 94/95 MAF sensor?
I seem to recall people using the Lightning MAF in the past, but I don't have a link to it.
Reactions: gkomo
Been reading up on superchargers. Was kind of dead set on the kenne bell, but was also looking at the Vortech v3 sci and that lead me to looking into the Paxton novi 1220SL. A lot of people are saying the Paxton is the Vortech v3 sci but with better parts (seems mostly the 8 rib setup vs 6 rib). Anyways, summit racing has the Paxton for $400 off, which puts it right inline with the Vortech… and roughly $2k cheaper than the kenne bell.
Thinking of pulling the trigger on the Paxton… thoughts?
I’m guessing with just the TFS heads and an ‘entry level’ supercharger, everything else mostly stock (injectors and MAF not?) I shouldn’t really be more than 350ish rwhp right? With the supercharger I don’t see a need to immediately swap the intake and I want to leave the cam stock.
Pics for pics sake:
I need to pair the injectors to the MAF right? Or does that all get sorted via the dyno tune? I’ll probably buy that Cougar MAF housing at some point. I need to be CARB legal or look CARB legal so something obvious like a Pro-M is out.
