You do not need the entire rear end. The axles out (meaning the axles and all the braking components) are the same between the V8 and V6 cars. So you can get the whole system off of a V6 car and install the axles and all the brake components into the Fox 8.8 housing. So you probably need some more information with regards to the 8.8 rear ends in these cars which is 87-98 8.8 housings are all the same. Where they differ is in the axle lengths and this is the 94-98 axles are roughly 0.75" longer per side and this was to make room for the ABS exciter ring that is pressed onto the axle shaft up by the flange.
Do not let the additional length of the axles worry you as there are all kinds of wheels with the correct offsets for this swap. You can run the Fox length axles but you will need a different axle to caliper bracket which will adds to the cost of the project.
To get the ebrakes to work you will need to modify the ebrake handle or install one from a 93 car or move up to a 94/95 handle. You can Google this. My car is a 93 so I did not have to make the modification.
