Gentlemen;
Once again I need your expertise. I pulled codes on my 5.0 I have the list below.
KOEO
67 - Park/Neutral Position (PNP) switch circuit open – A/C on during Self-Test
10 -
11 - System PASS
KOER
40 -
41 - HO2S circuit indicates system lean (right HO2S)
91 - HO2S circuit Indicates system loan (left HO2S)
** I recently changed the o2 sensors and still have the above error codes. I also clean the MAF sensor as well
Cylinder Balance Test
30 - Cylinder 3 is not cooperating to engine performance. Not working
** I am wondering if just changing the cable would fix this. I just don't want to get into fuel injectors.
Got description from https://obdadvisor.com/codes/ford-obd1-codes/
Once again, thank you very much for your input. I greatly appreciate it. I need the car to pass emissions. It has not failed yet but I would like to have the highest chance of passing.
Thanks
-Max
KOEO
10 -
11 - System PASS
KOER
40 -
Thanks
-Max
