The interesting thing about the stator wire is it looks like the other end just goes into a wire harness, so i wouldn't be able to like remove it and solder at a station per se, would have to be soldered in the engine bay. Not that its a big deal. Soldering itself didn't seem to hard i think my little wand iron just wasn't getting the thicker wires hot enough or something.Personally I don't feel crimp on connectors are a reliable connection. I saw you mentioned having some trouble picking up soldering. I'd suggest investing a bit into a decent solder station. It make a world of difference. Get a few different size tips and within 5 minutes you'll be a pro.
May as well face it you're gonna be repairing and adding in wiring for as long as you have the car. Get a nice solder setup. They aren't really that much. A Weller WE1010NA is all you'll ever need.
Congrats on getting the fuel tank finished up.
I'll pick up that Weller you referenced. Luckily i'm not out too much money on the little wand solder iron i have, i believe it was like $30, and may have its uses here and there.
Edit: the stator wire is so small, my existing iron may work. I'll give it a shot.
