Engine Fox body doesn’t run hot until I start driving
Rose5oh
22
12
Macon, GA
Hello all, in need of some help here.
I have a foxbody with a 5.0 in it. The only mods the engine has is an Explore upper intake and an E303 cam. I’ve replaced the thermostat 3 times. A water pump was installed a few years ago. It has an aluminum radiator with dual electric fans. I can idle the car after starting it and the temperature is about 185 degrees, no issues there. The problem is when I leave to drive. It will slowly creep up. After about 15 mins it’s running at about 250, in which case I’m back at home with the car shut off. And this isn’t even in summer whether. This has also been happening while cold. Anyone know what the problem is here?
I never checked this. Good point. It’s a motor that I received already put together and just changed the cam. But I always assumed explore upper and lower. Assuming that they match. Have you ever seen anything like this or a list of things that could cause this?
I only asked as its not likely that the stock lower is on the car with an Explorer upper. You can see here the difference which makes is physically impossible. Top is a stock 1987-1993 Mustang 5.0 lower and the bottom is a GT40, Cobra, Explorer 5.0 lower.
Some things that can make the car overheat:
1) Air locked - issues with refilling with coolant
2) Having the thermostat in backwards
3) Electric fans pushing air through radiator rather than pulling (will work at idle but fight the airflow when moving).
4) Installing a standard rotation water pump (our cars require a reverse rotation due to belt routing)
5) Routing the belt so the pump turns clockwise (standard rotation) - from what I know it cannot be done so just follow the standard way of routing it.
6) Head gasket issues.
I am sure the guys can add more.
Reactions: Mac131
I have 2-6 that you’ve listed. So I’ll get to work and try to narrow all of these down. Just hope it isn’t the head gasket. But it hasn’t really shown the typical symptoms of a blowed head gasket. I will try to keep you all updated. Thank you
Does the dual fan set up have a metal shroud blocking 2/3's of the air flow threw the radiator like all this cheap China made one's.?
So yes, as a matter of fact. It came from eBay. However, I have a foxbody of my own with essentially the same radiator except it has more mods and I haven’t had these problems . The one with the problems I speak of is my brother’s car just so that there isn’t any confusion.
My foxbody has a 306, dss flat tops, tfs top end, but a nitrous comp cam instead of the tfs stage 1, sct chip. Temp stays at 165 when traveling and the highest it’s probably been is 225-230 in traffic, if that and that was in 95 degree weather with the AC on.
But I know it can sometimes be an issue. So thanks for mentioning that
1. do you trust your gauge? Maybe use an IR thermometer
2. Make sure you have an air deflector below the front bumper, especially if it's a GT
3. Remove the shroud and see if it frees up enough air to keep temps down. Obviously, you'll need to go highway speeds and avoid trafic for this test.
I agree with others, I've seen terrible shrouds limit air flow.
Reactions: Shakerhood
The air dam deflector i completely forgot about that! That’s one thing my car has that my brother’s doesn’t.
But yes I do trust the gauges. I’m going to buy an IR thermometer anyway and Ill try the suggested things if I have to. Hope it works!
There are also pieces on the sides of the radiator that redirect the airflow to go through the radiator.
There are also deflectors on the bottom of the frame rails behind the radiator. They are part of the whole system to help with control of the airflow through the engine compartment.
https://lmr.com/item/LRS-8310B-K/5-0resto-mustang-frame-rail-air-deflectors-79-93
And fyi....
or if you'd prefer an original Ford part, rather than a repop....
Reactions: Rose5oh
And fyi....
Thanks man
Reactions: 85GTStangGuy
Is your water pump spinning in the correct direction? Not sure if ford does a reverse flow pump?? Did you install the belt the correct way??
EDIT.. I see Aerocoupe already asked these questions....
Hello all. I’ve got good news. I fixed the car. All it needed was an air dam deflector. I took the air deflector from my car and attached it to my brothers to see if it would work and it did! Now I don’t have one but I will in a few days. Thanks for all of the input from you guys. It’s much appreciated. Here’s a pic of our cars. My brother’s is on the left
Good deal. Glad that worked. I'd still be concerned, given that an LX has an open grille. My experience has led me to believe that they aren't strictly necessary on LXs, which means you might still have some kind of constriction to airflow that is not normal. This could be, and likely is, due to the shroud, and I get that you/your brother are resistant to changing it, but it may also be due to clogging in the radiator, A/C condenser, etc... Since it's free, it definitely merits radiator & condenser instpection/cleaning/straightening fins as needed, etc..,
  • Useful
Reactions: General karthief
I replaced those and they made a world of difference. I also replaced the
Mustang Frame Rail Air Deflectors​
