This looks like the info I received when I checked into the " lifetime" warranty on my Lowes bar be que......
You
ing got me
ing got me
Kid you not... Purposely done that way so I could not get any " lifetime" warranty items...... Do you want to know about the phone call??? same thing...Youing got me
I think they were saying ' We got you round eye" ........
You need to check the wiring going to the MAF.Hello, I am currently experiencing the same black smoke issue and the code 26 has returned. Is there any other solution than replacing the MAF again? Please help.
Thank you. I disconnected the maf and checked ABCD. A is 12v, B is earth ground, how do you check C and D? With the engine off, I got 29.3 ohms between B and C, and 100 between B and D.You need to check the wiring going to the MAF.
What part would you measure in step 7? Between C-D?Updated 05 July 2022 to add rough idle when cold and smooth idle when up to normal operating temperature. See the EGR tech information, section #15 for more help.
Many of you are familiar with the "Cranks OK, but No Start Checklist for Fuel Injected Mustangs" checklist and the No Crank Checklist. They are very effective in finding and eliminating the problems by use of a systematic process that checks and eliminates possible causes. This idle problem checklist will use the same troubleshooting strategy and methodology.
By the term surging idle, I mean an idle that...
- jrichker
- 1986 1993 86-93 check engine light code 67 cranks ok dump codes eec-iv mustang no start
- Forum: Fox 5.0 Mustang Tech
Step 7
c-B? d-B? ?
If so, does this mean there is a problem with the MAF I purchased? I checked the smell of the engine oil and it smells a bit like gasoline, but could this be because I've started the engine many times with black smoke coming out?From the checklist:
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
I checked the wiring to the MAF and the Ω from the MAF to the computer. I don't think there's a problem.From the checklist:
