Please help me. My 91 Mustang has been doing a lot of work, but the idling is unstable. I think the fuel is rich. Please tell me how to fix it. I've tried many things but can't fix it. As the water temperature warms up, the idle will go up and down. When I hit the accelerator, black smoke comes out.
The replaced part is
・distributor
・spark plug
・spark plug wire
・coil
・injectors FOTE-D5A
・MAF
・BAP
・O2 sensor x2
・TPS
・IAC
・ACT
・ECT
・fuel tank
・fuel pump
・filter
・pressure regulator
View: https://youtu.be/h3wNS9SllME?si=KXrWoeikD7zq7CRq
At about 9:30 seconds, the engine starts idling up and down and the engine stops.
View: https://youtu.be/mZocYssj7iY?si=IRb6XFaCTTOFQWdT
Even if I check the No. 1 spark plug wire with a timing light, the idling will be so erratic that the timing light won't respond.
View: https://youtube.com/shorts/I9sbMwCajng
black smoke
Please provide information on repairs.
・distributor
・spark plug
・spark plug wire
・coil
・injectors FOTE-D5A
・MAF
・BAP
・O2 sensor x2
・TPS
・IAC
・ACT
・ECT
・fuel tank
・fuel pump
・filter
・pressure regulator
black smoke
