Got the filter assembly in, I was right that it was just those wires taking up space in the channel that the filter cover is supposed to be in. With those out of the way the filter cover can sit lower and now doesn’t hit the head unit (still super close tho). This is how I did the wiring:
I actually added one more tie mount and tie wrap closer to the radiator but once I test fit it and it worked I didn’t want to take it back out to take a photo.
Here’s a photo of the new clearance. But wait there’s more! As you can see my new problem. There is no way my MAF connector will reach the MAF, I took off the relay and tried to reroute the cable, no chance. Do they make MAF connector extensions?
Anywho, a problem to solve for another day. Got back to the inlet elbow, it’s 100% the fuel hardline that is preventing the elbow from going on. I am so close, but just need a little more clearance, this is as far as I could get it using all my strength:
It’s like on good on the top, but on the backside and bottom it’s at least an 1/8” off. You can see my mirror there where I’m forcing it on while watching what’s going on the backside. Wouldn’t budge. One thing that worked a little better was putting the elbow down in from above (with the open end pointing up), then twisting it towards the passenger fender as you’re putting it on the head unit. The other pain in the but is the A/C line. It’s like not preventing anything, but it’s definitely in the way.
So here’s where I quit tonight:
I’m going to remove it, figure out the fuel line to get that out of the way then try again. I gave up out of frustration but I couldn’t even get the fuel line out of the bracket holder. There’s just no room to do anything.
Oh and
@Noobz347 i was wrong and can’t just loosen the head unit and bring it forward because it bolts to the other wrong side of the accessory bracket. I really don’t want to mess with the accessory bracket so I’m going to go the fuel line moving out of the way route.
