So with the higher octane fuel you can be a little more aggressive with the timing. Rule of thumb is to pull two degrees every 50 hp of nitrous. With a lower octane you may want to pull 5 degrees for a 100 shot vs 4 degrees. Again, read the plugs and run the fuel a little fat. You can always lean it up when its fat but if you start lean then thats when things get torn up. Best thing to do is run a knock sensor and have it back timing out.
Higher octane is more friendly to a nitrous tune and you can be more aggressive i.e. get more power our of it but like any other power adder you can work up an 87 octane tune.
