I just had a thought but store it away for later:
I have only ever seen this once before and it was on an earlier model year than yours.
You may have a return line restriction that is giving you a false FP reading at idle. What I mean is that when the injectors [do] open up, they consume enough fuel volume that your regulator [becomes] the bottleneck vs. whatever might be downstream.
It would be semi-simple to check by disconnecting the return line at the rail and running a length of hose into a fuel can.
Not of course, until after you get to the end of checking out your fuel inlet suspicions.
I mean... even a partially pinched return line can cause something like this where the pinch is acting like an FMU but without boost reference.
It came to me as the result of another discussion with @from6to8 this morning.
