Hi all,
Hope to get some ideas about how to solve this suspension issues On my 90 GT I have Bilstein all around. At the front I have BSN-F4V36413bh5 (BSN-35-041382)and have a noise specially out of the driver side strut. The strut has no leaks and damps very good but there is a play and knocking sound when pushing/pulling from the top of the tire. It seems like the cartridge is moving inside the yellow tube.
If anyone is using the same struts did you have or having the same issue? If you fixed it how did you resolved that?
On the pic I indicate with a green arrow the point where I feel of a bit of too much play and the rd arrows the the direction the cartridge moveing inside the yellow tube (not talking up/down but Inward/outward)
The noise is too annoying considering that those struts are stiff, have polyurethane control arm bushings and spherical camber plate bearings. So the suspension is very solid and any over play magnifies the noise exponentially.
Those struts aren’t cheap as to have the replace them…
I appreciate any help regarding this issue
