Engine Random hanging idle
I have a 88 Saleen… Cali mass air, rebuilt 347, e303, BBK 70 mm TB with Pro M 77 air meter calibrated to my 30 lb injectors… Bisanni equal length into BBK 2.5 high flow cats, SuperChips chip… engine had 8-10 k miles before this problem started…
While driving random times after start, cold or warm, engine rpm hangs at 2100! Since the issue, removed chip, installed new coolant and air charge sensors, EGR, BBK TB with new TPS, new BBK calibrated mass air meter…. Yes base idle reset, TPS set to .87v…. Timing at still at 13
-If I shut car off, problem goes away for a few minutes.
-if I unplug IAC idle drops to normal, plug it in and idle jumps back up
-if I unplug TPS, idle drops to normal, plug it back in idle stays normal.. drive the car and within a few minutes, idle jumps back up.
If the engine was running when you pulled the plug on those sensors you caused a code to set, so checking codes now would be really confusing, you need to clear the codes and drive the car around in various conditions then check codes with engine at operating temp.
Just my opinion.
Reactions: Mindseye007
This is the proper way to do it:
One further detail to that first line - set idle below 600 RPM with IAC and spout connectors disconnected. The lower you can set this and keep car running the better IAC can control idle.
All items listed in above posts , I have done after new BBK TB and TPS. Old TB had a loose sloppy butterfly.
Car still gets the random high 2k idle! Anyone have info about TPS voltage spike above 5vdc? I’ve heard if that happens, ECU will go into a weird program mode(limp mode?)
I tested my BBK TPS… seems to swings nice from .8 to 4.8 at WOT… according to my voltmeter. However putting my Motorcraft TPS back in, car has much better drivability and response! How inaccurate are the BBK TPSensors? Could that have caused a voltage spike to the ECU?
