Electrical How To Pull Codes From EEC-IV In 86- 95 5.0 Mustangs
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
@Noobz347 - The code dump procedure isn't in the sticky - you may want to add it...
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
The STI has a gray connector shell and a white/red wire. It comes from the same bundle of wires as the self test connector.[/B]
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Adding some useful info. Copied/pasted from another forum. Credit to Joel5.0
These are the following codes which will display a check engine light on the 86-93 Mustang. They will display the CEL if the condition is present, but will turn off the CEL if the condition is cleared
CIRCUITCODES
ACT54, 64
ECT51, 61
BP/MAP22
MAF26, 56, 66
TPS23, 53, 63
EVP31, 32, 34, 35
HEGO(1)41, 91, 42, 92
(1) Based on a "lean-rich" switching counter timer function.
Also, key to know is that when a key sensor is found to be in fault, the ECU will default to a Failure Stratgy to compensate
The Failure Mode (FMEM) strategy protects vehicle function from adverse effects of an EEC component failure. The strategy recognizes open or short circuit failure for six sensors: MAF, TP, ECT, ACT EVP/EPT, and BP. In general, if the continuous Self-Test strategy recognizes a failure the FMEM strategy will execute an alternative vehicle strategy. The alternative strategy disables logic which relies on realistic sensor values. Some sensor FMEM strategies also substitute a "safe" value for the bad sensor
What does that mean? Well this chart shows what changes if a disabled sensor is detected
NOTE: decel fuel cutoff is only enabled on 1993 cobra ECU. All other 86-93 mustang ECUs lack this programming.
  • Useful
Reactions: General karthief
What to expect:
Alternate methods:
i have a 1990 that has a 93 engine and ecc/ecu harness, is it necessary to do this test while the engine is running? i have a pretty bad misfire but the engine will idle, id rather not idle it until the misfire is fixed in case i cause any further issues. thank you also for the specific test walkthrough, great information!
There are two sets of codes you can get:
KOEO - Key On Engine Off / These are any latent codes that the EEC stored since the last time it was run and not cleared.
KOER - Key On Engine Running - More self explanatory: This will provide codes for sensors that [currently] out of range.
Good write up but you are missing a small piece. On the KOER test, after the engine speeds up and returns to idle you should get a single flash (goose test) When you get this single flash you quickly depress the accelerator to the floor and release. Then the computer will run a few more checks and then start flashing codes. If you don't get the single flash the computer most likely does not see the clutch depressed or does not believe the automatic transmission is is in park or neutral. This clutch in or in park check is so the vehicle does not unexpectedly move.
I've never pushed my clutch to the floor when doing a KOER test. Does that mean i'm missing out on some tests?
I typically just start the car with the (manual) trans in neutral, get out and press the test button and let it go.
What to expect:
Alternate methods:
I have this code reader. Problem is it will not go into self test mode. I just put new batteries in it. I think I fried my ECU
Suggestion would be to try and dumping the codes manually and if you have no success there then it is most likely the ECU and it will need to be repaired.
