I ran TFS twisted wedge heads 170cc (same as my current ones) with 1.7 rockers on my last fox which was a 331 and used my stock valve covers but I had an engine builder do the entire long block so I don’t know all the specs from memory anymore. I probably have my build sheet in a binder somewhere.I run them on my 331 but have tall aluminum valve covers so no issues with clearance.
I don’t recall which rockers I used but want to say the TFS 1.7’s. I think the oil baffle may need to be modified to run stock valve covers.
There is more to them than the Comp Cams magnum's I run in the T-Bird but I would say they are no more bulky than the old Crane Cams ones I had or my buddy's Hartland Sharps. Maybe I am missing something there?
I don’t want to mess with different valve covers so I may cancel my scorpion order and buy the TFS rockers. Research tells me they are shorter than the scorpions.
Run the supplied 3/8" studs and get 3/8" rockers, or spring the additional money to go with 7/16" studs and 7/16" rockers (same price).Umm yeah man, Hartland Sharp are some of the best.
From what I understand both the 3/8 and 7/16 studs will thread into the head so (I think) it’s just either using the 3/8 studs that came with the heads and getting 3/8 rockers. Or buy aftermarket ARP 7/16 studs and 7/16 rockers.As long as where the studs screw into the heads that is also 7/16". Makes no sense to have 7/16" rocker studs that have 3/8" threads where they go into the heads.
I will say that if you have the stock TFS springs on the TW 170's and a stock cam then 3/8" will be up to the task. Engine builder would be able to tell you better.
I think the real question is why does Trick Flow provide 3/8 studs with the heads if they are threaded for 7/16?Good to know.
I wonder though, whey would somebody have reason to use the 3/8 studs in a head threaded for 7/16?
