2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
joeybuddy96
23
tl;dr: I'm at a loss as to where some oscillations are coming from at 65 MPH.
I think there's leaks at the pinion seals and at the rear cover gasket. I'm putting together a shopping list of what all I need to replace. I think there are two pinion seals, one on the driveshaft end and one on the pinion end. There's a lot of oil buildup on the brake rotor mud guards, so I'm thinking that's gear oil rather than brake oil, meaning there might be leaks on the axle seals also. *If* there's something wrong with the axle bearings or differential bearings causing wobbling, now would be the time to replace those. I just don't know which bearings or seals in the differential exactly are causing it. Rebuilding a differential is a very precise job, with like .002" tolerances in adjusting the pinion and ring gear alignment, so I only want to replace what needs replacing. I've seen rebuild kits that include carrier, pinion, and setup bearings and races; a pinion seal; and a housing cover gasket. It might also mean getting new crush sleeves or spacers, clutches, and carrier & pinion shims. I don't know if it's possible to put things back how they were or if everything needs to be readjusted from scratch. I think the differential ring gear size is 7.5", the gear ratio is 3.27, it has 28-spline axles, and it's an open type, if I'm reading this website correctly. Idk if changing to a 31-spline axle differential matters, but I guess I'd switch to that if I end up needing to replace a lot of the parts in it or end up buying a completely new one; the problem would be that I think you have to have a 8.8" compatible housing that could hold a new 8.8" compatible carrier. That means taking an 8.8" housing off at a salvage yard from a V8; I'd be able to install axle dampers if I got one of those.
I'm getting vibrations once it hits 65 MPH, at about 2100 RPM; the vibrations increase in intensity over like 10 seconds, and decrease in intensity over like 10 seconds. I've revved it to 2100 RPM in neutral, but there are no vibrations there. I've changed out the ball joints, control arms, and inner/outer tie rods. Given that the vibrations aren't constant at 65 MPH, and have a rise/fall cycle, I don't think it's the motor mounts or any rear control arm bushings; it's a pattern that belongs to some kind of rotating part. I don't think it's the drive shaft, because if it were, I'd be feeling it at neutral at 2100 RPM. I don't think it's the rims, because I've swapped where the wheels are before; I could try swapping them around again, since after I changed the control arms, the vibrations decreased. It could be that one of the wheels needs to be re-balanced. I don't think it's any wheel bearings, since I'd be hearing that loud roaring sound if it was; I've had a bearing go out before, it's hard to miss, lol. That leaves the rear axles and the differential. I'd like to think it's the rear axles or axle bearings, since the differential has like two dozen different parts to it. I don't know how the axles could possibly get bent out of shape, since they're inside the axle housing. If it is the differential, I have no idea which part it could be; I've never had to disassemble one before. I could just forget all that stuff and get a pre-built differential, but that'd be about $400 more than rebuilding it, but if that's not where the vibration is coming from, that'd be pointless. It's a labor & time vs money trade-off.
Yesterday I drove it in low and 2nd gears on mostly smooth roads at 2100 RPM to test it out. I couldn't feel any of the same kind of vibrations that I get at 65 MPH.
I would lean toward your driveshaft vs the differential and axles. The reason you don't feel anything in neutral is because the driveshaft isn't under a load. The reason you don't feel it at lower speeds is that it hasn't reached a high enough RPM to induce harmonics that would be more prevalent at higher speeds. Replacing U-joints is a lot cheaper and easier to boot, I'd suggest starting there.
Reactions: joeybuddy96
Both. You can hear the interior trim and stuff rattling, too.
Driveshaft is the most likely culprit - as someone else suggested. Easy thing to try - remove it, and turn it 180 degrees and reinstall it. Of course before you reinstall - make sure you don't have a failed u-joint right off the bat.
If the vibration changes at all - you've found your culprit more than likely.
That sounds like a good idea. I already bought two new u-joints before I saw your comment. I planned on changing those out anyway. If doing all the replacements I have planned doesn't work, I can always try flipping the driveshaft around or taking it to get it rebalanced.
I also got a cover gasket, pinion seal, output shaft seal, and bearings & seals for the axles (because one of the axle seals appears to be leaking). I only want to get all this stuff done once, and get it all done correctly. It's my daily driver, so I can't just get this done halfway and wait a week for more tools or parts to arrive if I get stuck at some point during the replacement process.
I did have another quick question. I'm going to be replacing the pinion seal (because I think it's leaking, see photos), which means taking the pinion nut off and putting a new nut on (the new nut arrived with some dry threadlocker pre-applied to it). I want to make sure I'm not ruining the bolts that attach the flange to the yoke; I don't want to bend those bolts or mar their threads. Do I *need* to buy one of those pinion flange holder wrench thingies, or is there some other way of getting the nut on and off without special tools? They're basically just a thick metal plate with some holes drilled through them. I don't know what brand to get, if so. There seem to be a lot of $20 ones that aren't compatible with the 7.5 differential flange, but I'm sure there are some that sell for around $30 that'd work (again, assuming the holder required for the job).
I'm going to be doing the replacement with the car up on jack stands, so there won't be much clearance or room to get a lot of leverage. I plan on not using an impact wrench to get the pinion nut on and off, because I'm not going to be using a beam torque wrench to measure drag--I'm just going to mark the nut and the pinion, count how many turns it takes to remove the nut, and line it back up *exactly* like it was when I removed it and no more than that (I've seen some articles that say to tighten the nut slightly further than that mark to make sure the crush sleeve has the same force on it as before, but I've seen more people saying to not to overtighten it). I really don't want to mess up the backlash and have to figure all that out or get a beam torque wrench I'll never use afterwards. I wish I could heat up the nut with a propane torch to make it easier to tighten down, but if I do that, I think it'll melt the threadlocker and rtv on the nut, so idk what to do about that. I can't even put oil on the threads because it might interfere with the threadlocker on the nut keeping its grip on the threads.
I plan on putting a small amount of RTV on the yoke splines (not the pinion splines), but I don't want to put any on the seal itself, the inside of the cylinder, etc.. The seal itself absorbs oil and swells up to block gear oil from leaking out, so I don't want to disrupt the seal's surface contacts in any way. I've seen videos of people packing pink or red grease (probably high-tack wheel bearing grease) inside of the seal where the spring is, but I don't know what kind of grease to use for that; all I've got right now is regular old dark gray grease; I forget what kind it is (probably some kind of #2 synthetic); the grease and the gear oil need to be compatible if I'm going to try doing that. Do I have this right, do I need to put oil, grease, or RTV anywhere else?
are you sure your tires are balanced ? i'm sure you have but i don't see anywhere where you stated that you had them checked.
I got them balanced when I bought them, but they haven't been re-balanced since then.
Right now there are weights on:
FL inner & outer
FR inner only, no outer
RL inner only, no outer
RR no inner, outer only
Regarding the pinion yoke holder, if it wasn't clear already, I'm not crushing the crush sleeve again, so I don't think it'll take as much force to torque the new one down to spec, but removing the old one will still require a holder, I think. Ideally, I'd be wrong about that and I wouldn't need to buy one. Jegs has one for $15 (part number 555-81658) and Ratech makes one (product number RAT-18001) that is available for $20 from a bunch of different retailers. A couple of reviewers have mentioned that the Ratech one rounds out the 1/2" drive hole and could only use it with a 3/4" breaker bar or 1/2" to 3/4" adapter. A redditor said I could, "Buy a 4 ft length of 1.5 inch angle iron from Home Depot and drill your own holes, grind the center so the socket fits, done." A 4' length piece costs about $25, so it wouldn't be much different, I'd have to put in a couple of hours of work and electricity trying to get that done, though, assuming the drill bits I have would work and assuming I wouldn't need to buy a drill press (both of which might be big "if"s). I could repurpose the steel for other stuff later on, which I wouldn't be able to do with a prebuilt yoke holder.
I snapped one of the bolts putting the differential cover back on. It now has a slow leak, even with the other bolts secured. The gas tank cover makes the space too tight to fit a drill in to get the bolt extracted. If it's the body of the car behind that cover, then removing that isn't going to help anyway. So now I'm trying to figure out how to gey some kind of right angle adapter or tool in there that is compact enough that it'll actually reach the broken bolt. Let me know what your suggestions are. I could try to use a right angle drill attachment (possible brands are Titan and LaBear), with a drill chuck (Neiko brand). Right angle die grinders might be a possibility, but I've reas that their RPMs are too high for drilling. I can set my air compressor to a lower output, so I don't know if that's really a problem. I don't know if regular drill bits even fit onto die grinders, so someone tell me if they're compatible or if I'd need to buy another adapter for one. I do own an electric angle grinder (not a die grinder) and there is an angle grinder arbor to drill chuck attachment on Amazon, but it has almost no reviews and angle grinders have higher RPMs than drills, and trying to control that tool along an axis perpendicular to its intended angle in tight quarters seems like a good way to injure myself. The easiest solution would be to get a right angle air drill from Harbor Freight, but those are $70. There's a Matco right angle drill I can get used for $50, so I'll get that one if I try that solution.
I wasn't able to reach the broken bolt by jacking it up by the torque boxes. I ended up having to buy a right-angle air drill. I wasn't able to get the bolt out by drilling it out. It's just too hard to get it centered with the differential cover still on. I think if I really wanted to extract the bolt, I would have to completely take off all of the bolts, drain the gear oil, and use either a wide diameter drill bit or a conical deburring bit to make a centered depression in the bolt so that I could get a hole drilled for the extractor bit. It hasn't been leaking, at least, so the other bolts seem to be enough to hold the cover on tight enough to prevent leaks.
I got the extension housing seal, extension housing bushing, and the front differential seals replaced. I should note that the yoke nut was only at 3 in/lbs of drag. When I replaced it with a new nut, I tightened it down to about 11 in/lbs. The vibration is still present.
I guess my next step would be to get the wheel rims professionally checked for being out-of-round and re-balanced. As far as I can tell by eyeballing every rim while spinning the wheels while they're off the ground, they're not out-of-round (I know you can use tools from around your own garage to do it, too). I plan on buying a used tire and rim from the salvage yard. The front right rim probably ought to be replaced bc it got marred in Decwmber. The tire on it is new, so it's going on a rim that the rear left tire is on. That tire has little to no tread toward the inside edge. That in itself could possibly be causing the vibration.
Other than that, I think the next step is to get the driveshaft rebalanced. I don't think that's likely, bc once it's balanced, it's not like anything has physically changed about the driveshaft. It's not aluminum, it's not like it could be bent.
Joey, recommend you get the tires RoadForce Balanced vs standard balance. RF Balance is a bit more comprehensive. Also, tech will be able to tell if tires have a flat spot, unnoticeable to the naked eye. I had a set of Nittos that had plenty of life in them, but they had a flat spot that could not be fixed. Thus, replacing them with new ones, and in my case vibration around 70 mph was gone.
Reactions: DadLife0724
I got this message later in the day after I'd gotten two new tires put on it, so I wasn't able to pick out a shop with that equipment. They did check all four tires for balance (they were all balanced), but that doesn't mean they didn't have flat spots.
The tire shop put one of the tires that has some of the outside of the rim marred to the rear. I tested it and the waves of vibration seemed to have decreased some, but they aren't absent. I tried moving the tire with the marred rim edge to the front driver's side, but couldn't really notice any difference. So I took it to an actual mechanic's shop to see if they could track it down.
The mechanic shop wasn't even able to get it up to 60mph because of traffic and heavy rainstorms here. They did give me a long list of potential problems and charged me $100 for it, though. :( They said all four shocks need to be replaced and that the front brakes were stuck closed. The stuck brakes seem to me to be like they could be the prime candidate for trying to solve this.
The ABS light has been on since I've had the car back in like April of 2025, the traction control light never goes off, and I can attest that the ABS definitely doesn't work, since the brakes have caused the tires to skid during a hard brake when the car has hydroplaned multiple times, which I'm sure hasn't helped prevent flat spots on the tires any. I've gotten codes scanned at an auto parts retailer, and all that showed up were engine codes, but maybe the brake codes have to be scanned separately for them to show up. I'll have to get that checked out next time I'm at the retailer. I'm dreading having to chase down any kind of electrical problem. It could be a bad ABS module; there's one guy on eBay that tests and fixes Mustang ABS modules for $100, and another who has a 5-year warranty for $160, but idk who that is or if they're still doing it.
When I'd taken off the front passenger caliper to work on the control arm bushings, one of the pistons wouldn't compress, even with the cap on the master cylinder reservoir off and the bleeder valve open. I ended up taking off the caliper completely, and replacing the seals on one of the pistons. When I took off the rear right caliper to replace the wheel bearing and seal, I discovered that one of the bracket slider pins was seized up and I ended up having to use a torch to expand the caliper body enough to get the slide pin out. The mechanic said that the front brakes were stuck and not the rear ones, so even if the pads or rotors on the rear are warped, that doesn't really have anything to do with the front brakes being stuck. The mechanic said the front rotors are probably warped if the brakes have been stuck like that for any length of time and that the pads and rotors need to be replaced. He also said that the flexible hoses need to be replaced because apparently I put the calipers on wrong and the hoses are twisted, but keep in mind that the vibration preceded me messing with the brakes, not the other way around.
It seems possible that all four brakes might not be compressing back in when they're supposed to, so the big question is, "why in the world not?" Bad ABS module? Bad ABS distributor? Bad master cylinder? It wouldn't be the brake booster or power steering pump--those things push the brakes closed, not open. I don't know if there's really any negative force that pulls the brakes back open on '04 Mustangs, I think it's all just pushing, which is a pretty crazy oversight if that's the case.
Reactions: TPony and gkomo
I got an OBD II scanner on it to try to figure out if the ABS electronic module was working. The scanner is capable of detecting ABS modules, but it really doesn't have any information at all on what the ABS module is doing (e.g. doesn't display the ABS light and "trac off" light statuses, doesn't display if the brakes are being depressed, any detail coming from the brake sensors, etc.). It's my first time using it, so it's possible these are just artifacts from connecting it and clearing codes. It displays "U1262 (SCP) Data Link Fault", "P1000 OBD Systems Readiness Test Not Complete", and "P0161 Freeze Frame DTC". It's also incorrectly stating that the Malfunction Indicator Lamp status is off--that might be in reference to the "service engine soon" light not being displayed, but even that is just because I'd cleared the codes already.
So do the U1262, P1000, or P0161 mean anything significant, or am I still back at square one with trying to figure out what is activating the ABS/trac lights?
I got a new master cylinder. I also got an ABS module with its hydraulic distributor attached to it. It didn't fix the vibration above 60mph or the ABS light being on. The salvage yard ABS module was from I think a 4.6L, not a 3.8L. The barcodes on the two modules didn't match. I'm going to claim that it shouldn't matter: they're both automatic V6 base models. The error codes that come up now are C1165 and U1043. C1165 shows up on lemon manuals as a bad right rear sensor. I did break some of the plastic on it a while ago, but not the internal components; that shouldn't be throwing an error code. I could gamble the $20 on a new sensor, but it could be unrelated to the ABS light not turning off and the traction control button not working. It could be that if one sensor is detected as bad, the entire ABS system won't activate. That does make sense, since if three brakes activate, but not the fourth, the car is going to get out of control. It could be that *both* of the ABS modules are bad, which is possible, given how high the failure rate of the soldering on those has been. Now that I've uninstalled the first one, I can pay that one guy to inspect and repair the module for like $300. I haven't taken off the passenger side kick panel to follow the manual's multimeter tests for those components. I plan on testing those probably before I start paying for new parts or services. The entire problem of the brakes not working could be due to one of the electronic modules involved in the ABS, like the GEM or something, so it could be causing the entire system to lock up.
I made sure the push rod on the brake booster was adjusted to where it's just short of touching the inside of the master cylinder's piston. I didn't have the little H-shaped tool, so it took forever to get it approximately right.
The brake pads are almost completely worn down, and I think that's just from them being clamped closed all the tims and not fully releasing even when I'm driving 60mph on the interstate. Getting new brake pads is a must at this ppint, but that's not going to fix the underlying problem of the brakes not releasing. If anything, new pads are going to make it worse since they're thicker when new. This is one of my top priorities: fixing the vibration which is probably caused by the brakes not releasing. I've seen other forum posts mention that the brake lines could be collapsing from being worn out or stretched; what happens in those cases is that the fluid can be compressed and the lines handle that without problems, but the vacuum when the brakes are released causes the tubes to pinch closed. It's possible, but I'm pretty sure this vibration has been going on before I even touched any calipers; that's not to say they couldn't have just worn out from chemical decomposition over several years, though. I'm pretty sure that this is going on with all four corners, so it seems to me that the chances of *all four* failing at once makes the hoses a less likely cause. The hoses don't visibly look like they're collapsed, but all I can see is the outside of the tubes, so for all I know they're actually collapsed internally.
The metal pieces that the brake pads move back and forth over had no remaining caliper grease on them, even though I've made sure to put grease on those metal pieces the last time I was working on the calipers. That really shouldn't matter, though. They're capable of moving when I step on the brake pedal.
I've replaced the front and rear shocks. The rear of the car on the passenger side sits an inch lower that the rear drivers side. They're all the same brand and pretty much torqued the same (long story, just don't buy Gabriel brand). That asymmetry can't affect the brakes, though.
I'm tired of this wild goose chase. What advice do you all have?
