My favorite part of this hobby is planning out how to do things and putting alot of thought into it. Even simple things like a radio install. I usually start out with an overly complicated idea, then eventually distill it down something thats elegant and simple. Sometimes overly complicated is fun too though lol. While this was a bit of work, and seems sorta complex, its actually really simple and I'm happy with how it came out. It took me about 4 hours all together painting included. But I probably put 20 hours into thinking about how to do it.
So here's a trip into my wacky brain.....
I got my Ebay parts radio. I'm going to use the bottom mounting plate that hold the cubby to the radio.
I drilled out the rivits that hold the mounting plate. It's pretty sturdy steel so this is going to work well to act as a radio support.
I attached the cubby to the radio plate with the two screws and held my radio sleeve up against it. It's not as seamless as I wanted. There's a decent gap between the two peices as seen below.
I need to shorten the two legs that hold the peices together to bring them nice and snug. So I cut them off.
The thickness of the cutoff wheel was all I needed. So I clamped them back together and welded them back on.
Now it fits nicely. I clamped the radio plate to the radio sleeve and plug welded them together. The plate is thick steel, almost 1/8", the radio sleeve is very thin. To do this I set the welder to the thicker metal. To avoid burning through the thiner metal you focus the welding on the thick part only briefly dipping the weld on to the thin metal. If I blew through it would really have been a mess because it would be hard to grind it smooth inside the radio sleeve. This needs to be smooth as the radio slides in and out of it. So I use a small peice of aluminum as a backer. The weld won't stick to it. So I just hold it on the backside of the radio sleeve to act as a heat sink and further precaution to avoid a blow through.
With the radio plate and cubby fitting well together I welded a tab to the plate. The hole in the tab will slide over a stud I'll be installing.
Looking at it front the front. This is how I'll access the nut to remove the assembly.
I also made a small bracket and welded it to the metal portion of the center console. This is the metal frame that reinforces the center console and attaches to the floorboards. Its very sturdy, so mounting the radio to this will be very robust.
I tacked a 1/4-20 bolt in this bracket to act as a mounting stud. The radio plate assembly will slide over this stud and be secured with a nut.
Looking at installed radio sleeve assembly with the nut holding it in place.
The Blaupunkt is secured in the sleeve with some spring tabs. To remove the radio it comes with tools similar to the factory radio removal tools. So to remove the radio i just insert them and slide it out.
If I ever need to remove the radio sleeve and cubby to access my wideband controller or any other wiring behind there i just remove the 1/4-20 nut and it all slides out.
Part of the metal portion can be seen when this is all assembled and the center console installed. It was faded and had some scuffs. So I took the opportunity to paint it. This is the metal peice you see by your gas pedal sticking out of the center console. You can see the bracket I made and hold down nut in this picture.
Then touched up the center console black area. I actually had a piece of electric tape over it before becasue the red was showing through. I've been meaning to paint this for a while now.
Really happy with it. The radio mount is super rigid. Actually much more secure than the factory arrangement. This should sturdy up that area nicely.
