Hi all,
I must post this new one because I really don’t know what’s goin on.
My MPG are pathetic at the best, getting 9.5 or less miles to the gallon is unsustainable!
This post will be long since I’ll describe my specs and the things I’ve already looked into:
Engine 306 with 170 twisted wedge heads, flat top pistons TFS upper and lower intakes, TFS stage 1 cam, sparkplugs set at 0.054” and don’t see any dark stuff on them, 65mm TB, 19 lb injectors with no leaks, stock regulator with no leaks and pressure at 39lb vacuum on, brand new O2 sensors, stock 55mm MAF tube and stock sensor, 210lph fuel pump, rear end fitted with 3.55 gears, T5 Z specs with the right gear for the 3.55 rear gears and shifting at 2.5 k, cobra disc brakes with no pads rubbing, all four 245 45 17 tires inflated at 36psi, front cobra brake discs with no pads rubbing.
Sooo, with all of that information what in hell is going on with this horrible fuel economy???? Anyone has any idea what could be the problem???
I haven’t had any chance to buy an AFR gauge to monitor my air fuel mixture, but no matter what driving style I do the problem still there.
I don’t see any black smoke even at high rpm and the car is used mostly city driving.
I have an A9L and a A9P computers both in good condition but the problem still there…
Does anyone have any idea about this?
I truly appreciate any help on this issue, kind of desperate….
Thank you all
Thank you all
