Mustang5L5’s progress thread - Boom
For the hell of it I dumped all my symptoms and everything I did into Copilot and just wanted to see what it came back with. I gave it a pretty detailed/extensive list of symptoms and what i've done.
It said injectors.
:pop:
Thing is i can't run the engine unless I get adapters since i changed my injector harness from EV1 to USCAR connectors. But my test is the key prime test. It will NOT prime past 29psi. If this line of thinking is correct that's the pressure one of the injectors must be leaking at. I think if i just swap the injectors, a key prime to 39psi will be VERY telling. The injectors are ahead of the regulator, and the system acts like i have a leak.
Forgot to mention. I changed the oil and it had gas in it. Also, the last few times i've pulled the intake, very wet with gas. Now, i looked past that because I've been doing a lot of cold starts to check the fuel pressure without fully warming the engine up...but I am more suspicious now..especially since I only have 1 wideband installed on my pass side.
Didn't swap yet. It was a beautiful night out last night and I took the kids out in the convertible for Ice Cream. It was absolutely perfect top-down weather. Going to rain all day Sat.
Single 47# injector is part number BR3Z-9F593-A. $60 plus shipping from Tasca. Nothing would make me happier than to place an order for that part.
I don't know all that much about leaking injectors, never had one (i have had a #39 stick, but tapping it with the back end of a screwdriver fixed that).
If it were leaking, would it leak enough to never let it get past 29psi?
I would think it would go past that, then bleed and if it was leaking, why stop at 29 every time?
The thought crossed my mind there, but didn't you say this was happening with 19s? Also, hard to imagine a single stuck injector overwhelming a 190 LPH pump, even a 47, and what kind of crap parts would they have to be to have 3+ sticking?
Honestly, as thoroughly as you've gone through things, it very well could be a combination of things contributing. I'm not ruling out an injector problem, but it would surprise me if it was the only problem that sucked the pump dry & caused a fuel pressure drop.
I'm going back to a regulator issue. Torn diaphragm, despite your efforts. Did you smell the vacuum line to see if it reeks of gas? Introducing fuel there absolutely sucks fuel back through the intake & causes pressure problems.
Where did you measure resistance when checking the wiring? What about something going on with the tank harness? Getting good voltage/resistance to the end of the body harness, but something going on from that connection to the actual pump hangar?
That happened to me. Pump died and turned out it was mechanically fine, but there was a short in the pump bracket wiring. Was obvious because when I applied 12v to the bracket plug, it wouldn't go, but directly to the pump did. Could it be some kind of short that's allowing partial voltage?
How hard would it be to disconnect the feed and return line at the fuel rail and temporarily plumb them into an external regulator? If it builds full pressure at prime, the problem is on the engine. If it still only builds to 29psi, it's somewhere in the lines/tank /pump. At least you could isolate it to one section or the other.
Did you have to do any wiring upgrade to the hangar when changing the pump out for the first time? When I put my 255lph pump in it required some minor wiring changes… maybe something got fubar’d with that so the problem is pump agnostic.
I’m far from an expert but something tells me it’s wiring related from the tank harness to the pump.
That or a butt connector got lodged in the S hose ( like what happened to LMR ) lol
I can't help but think regulator too.
29psi just seems like a too consistent number to be much else.
The fuel system isn't very complex and even if there were an injector problem the 190lph pump and the regulator should be able to compensate by dumping less fuel back in the tank. Any NA 302 easily runs on a 155lph pump, so the 190 would be more than enough to add the lost psi.
And if there was an injector problem, where exactly would all that fuel be going that you aren't aware of?
I just changed the oil, and it smelled gassy. It could be from all the cold/starts and not fully warming up while i sort though this. It also smells rich in the garage, but my AFR at idle is only 13.8 because any leaner get lopey. FOund some fuel in the intake as well when I pulled it. Coud be just tune related..but i can't put this out of mind.
Sounds stupid but could it be the fuel pump sock restricting flow somehow like maybe getting partially sucked into the inlet?
I replaced the sock with a different one. No change. If i drop the tank again i will remove it completely and see what happens
original fuel pump wiring is not being used. I ran brand new 10G wire from the battery to the fuel pump through the hanger. The stock wiring is only activating the relay. zero change.
No gas smell in the reg. I've tried a few regs. Swapped a stocker on. No change. Bought a brand new kirban diaphragm. No change.
I almost have the injectors swapped out. Lets just check this off the list and then we can circle back to revisiting some of the other items again.
Swapped the injectors out.
No change.
By that i mean i see the exact same behavior when I key prime and run the pump. Key prime goes to the same pressure (29psi) and then drops and holds at 23.3psi. I've been seeing these numbers for months now so they are drilled into my mind what I expect to see when i do various steps. Zero change from the 47's to a spare set of 30's I have.
I think i'm going to take a step back and verify my pressure readings. "borrowing" a nice caibrated mechanical gauge from work and picked up some fittings to connect to the rail.
Also borrowing a vac hand pump to play with that to see if this is manifold pressure/vac related. my FPR is hooked to stock location so shouldn't be a prob. Using a hose and my lungs, i do see a response in pressure from the diaphragm when i suck/blow.
At this point i need to circle back to the basics and start over. Like someone said, these fuel systems are not that complicated. This should have been easy to find. Step #1 is confirm my pressure readings, so I'm going to do that (again).
Actually step 1a is to put the 47# injectors back in so i can run the engine
Ahh when you said gassy oil I would have guaranteed injectors... But not 2 sets exactly the same..
Not the pump either, that pump was flawless in my car..
Are you seeing the same psi on mech gauge and FP sensor (do you have a sensor on your set up?)
The gassy oil is prob the tune. I’m a little rich at idle and have spent way too much time idling the car dealing with this. I was working on leaning this out when I found my issue
I've tried a mech gauge and a few transducers. They all show the same. I have another mech gauge I'm going to set up with a tee so i can run the transducer and gauge together
I’m pretty much starting over and starting with verifying the problem exists. Also going to try a different vac source even though I’m using the stock location port
Found this in my logs. I want to put this here just so i have a record of it and it doesn't get lost.
This was with the vac line off and capped. So fuel pressure was static 39psi
For those not familiar with megalogviewer, the blue verticle line is the snapshot in time and to the right are the numbers at that moment and the corresponding colors.
So yellow is my TPS. Essentially when i hit the gas for a rev. You can see MAP immediately follows (0.1s behind the TPS hit), so no funky things happening there. White is my FP. I'm sitting at 39psi and then the rev comes and it drops to 30.1psi. It then recovers. You can see my RPM dips, and my AFR goes lean. Not shown is injector pulse width. It goes from 3ms to 14ms during the blip, so it's trying to add fuel.
@Mustang5L5 I have a theory that could explain all of it. Been thinking about this for a while. Can you post a screen shot of your fuel pressure sensor set up in your software. You should have a screen with units and sensor types. Open them up to show the choices and what you have selected.
Edit- Also a pic of your FP transducer
Here you go.
This is the exact main transducer i've been using.
