For the hell of it I dumped all my symptoms and everything I did into Copilot and just wanted to see what it came back with. I gave it a pretty detailed/extensive list of symptoms and what i've done.
It said injectors.
Thing is i can't run the engine unless I get adapters since i changed my injector harness from EV1 to USCAR connectors. But my test is the key prime test. It will NOT prime past 29psi. If this line of thinking is correct that's the pressure one of the injectors must be leaking at. I think if i just swap the injectors, a key prime to 39psi will be VERY telling. The injectors are ahead of the regulator, and the system acts like i have a leak.
Forgot to mention. I changed the oil and it had gas in it. Also, the last few times i've pulled the intake, very wet with gas. Now, i looked past that because I've been doing a lot of cold starts to check the fuel pressure without fully warming the engine up...but I am more suspicious now..especially since I only have 1 wideband installed on my pass side.
Didn't swap yet. It was a beautiful night out last night and I took the kids out in the convertible for Ice Cream. It was absolutely perfect top-down weather. Going to rain all day Sat.
Single 47# injector is part number BR3Z-9F593-A. $60 plus shipping from Tasca. Nothing would make me happier than to place an order for that part.
