Progress Thread The next "big" project for my Cobra - T-top conversion coming soon!
Cool find! You know that you need to make a lot of pics for us in the forum... of both: chicks and cobras
I also bought a new "old" (2010) car :cool:
will post pictures, but it's a typical European Ford. Its low mileage and incredibly clean...
Good luck with your find and tune.
Reactions: LILCBRA
I've actually thought of trying my hand at a YouTube documentary of the process. I found one other guy that cut the structure apart, but it's a long and bloated video with a lot of unnecessary stuff in it. Seems that most videos are about 10 minutes so I suppose I'd try to edit them down to that timeframe. I'm sure there is more than one reason that they're that length, but I would say that part of it is keeping someone's attention. But here's that video.
View: https://youtu.be/xRlzUoM7jrg?is=aAak8vANgSrm2VZf
do you re-use the rear mounting bolts for this subframe kit?
Yes you do. I ended up using a breaker bar and socket to twist the spot welded nuts off of the brackets, reinserting the bolts and installing the supplied nuts.
Reactions: DadLife0724
I've really been thinking of this conversion over the last couple days and how the car will end up being weakened some by it. I think what I'm going to do is try to fabricate some web bracing in addition to the added factory T top bracing. I've got a couple rough sketches of my ideas done and think it should work well. I'm planning on making them a bolt in upgrade like the subframe connectors are designed. I figure that way, in the event I need to access anything that they may block, I can remove it all as one unit.
The one difference I've measured out is that the 3/4" square tube I initially thought would be right will be a 1" square tube, 1/8 wall. The clamping piece for the outside of the pinch weld will be 1" x .25.
Did some measuring and ordered steel. I'll pick it up this weekend but probably won't get started on it right away.
I went with .188 instead of .250 flat stock mainly due to cost. It was an additional $50 if I went with it instead and I don't think that the thinner material will sacrifice anything for how I'm intending on using it.
I'll have to take inventory of my rivnut collection to see if I need to order more or not. I'm thinking 5/16 bolts - I feel 3/8 would be overkill and 1/4 wouldn't be quite big enough.
