1989 mustang 5.0 crank no start
I have a 1989 ford mustang that I’m working on and we installed a blueprint engine and aftermarket manual transmission aswell as aftermarket injectors and a higher log fuel pump it started for a while and ran I shut it off one day and it wouldn’t start up again just cranks I tested fuel pump and eec relay and all of the fuzable links by the battery\ starter solinoid
Have you checked for codes? Not sure what a “higher log fuel pump” is.
This is the thread that everyone uses for crank no start:
  • Useful
Reactions: General karthief
I meant lph and yes I have and there are none
ECU should communicate and provide a Code 11 for system pass with the KOEO test. When you do the KOER test you should get a Code 10 to depress the gas pedal to WOT and then get another Code 11 for system pass.
If you do not get any code then the ECU most likely needs to be repaired as mcmahst stated above.
One thing that indicates a bad ecu is the fuel pump runs continuously with KOEO. If the ecu is working correctly, when you turn the ignition to KOEO, the pump should prime for a second or two only and then shut off.
You need to get yourself a tuning chip ........You changed way too much to be considered a stock OEM Mustang especially/possibly the camshaft...do you know wht camshaft is in it?
you need to dial in the fuel pressure with an adj regulator to 39psi with hoseoff as all fueling on the A9L is done at 39psi and if you go higher youll need to rescale the whole fuel system instead of adjust it
My tune is on the right stock a9l on the right....when you change parts the numbers dont change magically..
These are just a few of the things that need attention......Theres lots more that need to be tweked and adjusted to work with things not on the OEM menu for the ECU...
