1989 mustang 5.0 crank no start
I have a 1989 ford mustang that I’m working on and we installed a blueprint engine and aftermarket manual transmission aswell as aftermarket injectors and a higher log fuel pump it started for a while and ran I shut it off one day and it wouldn’t start up again just cranks I tested fuel pump and eec relay and all of the fuzable links by the battery\ starter solinoid
Have you checked for codes? Not sure what a “higher log fuel pump” is.
This is the thread that everyone uses for crank no start:
  • Useful
Reactions: General karthief
I've put the Checklist in to a PDF, so it's easier to use once printed out in the garage. I also had to use it for my '89 and my final outcome after replacing the fuel pump was that the spark from the coil wasn't good. While you could see spark it didn't look quite right, $35 later see was up and running!
I meant lph and yes I have and there are none
ECU should communicate and provide a Code 11 for system pass with the KOEO test. When you do the KOER test you should get a Code 10 to depress the gas pedal to WOT and then get another Code 11 for system pass.
If you do not get any code then the ECU most likely needs to be repaired as mcmahst stated above.
