To make it easy, yes. Or, if you're good at fabricating, you can cut and weld it to accommodate. But your shifter location will also move if you've not noticed that too. The sheet metal may interfere with the shift handle once it's installed if you modify the cross member to fit. I believe that's one reason why most everyone that I'm aware of goes ahead with the input shaft and bell housing swap.
