Suspension Electric Steering rack??
2013 v6 electric steering rack went out and trying to buy a reman or used one. Seems hard to find in stock from reliable sites. I found one on Rockauto but says it’s for 19’ wheels. I don’t know what stock wheels were as I bought with aftermarket 20s . Does it matter which rack I buy and any ideas where to buy cheaper than 975 after core???
Cheaper... wreckers if you can find one.
Your bar code sticker in the door jam will say what tire size your car came with.
What do you mean "went out"?
Is there a EPAS code or a Stabilitrac code? A warning light on the dash?
Depending on the code, it may just be a communication wire to the EPAS control module that is corroded.
This could be fixed with a wire repair.
Or the whole rack went bad.
It is usually the control module or the motor that fails, although the belt internal to the rack could be stripped.
Then, if you put a new rack in, it will have to be programmed to the car to get it to work.
Should probably do a more through diagnostic before spending money.
There was No Codes pending or permanent. The steering wheel was not budging. I diagnosed by checking codes, fuses, wiring etc. I removed the rack to open and check the belt for breakage. It was not broke however looked pretty nasty inside like possible water damage I’m guessing. So looking as if I need to buy rack. I am not sure how to get one from under car at salvage yard and figured easier to buy online. Only thing is I haven’t found cheaper than 950 on rockauto other than eBay but not sure how much I can rely on the eBay ones being reliable as I have never bought something like this used on eBay.
