90 mustang no spark
djj62478
47
Nj
Im going crazy here, I was having surging issues and finally got the car somewhat straightened out and now this. I somehow lost spark, it started when I noticed the rpms jerking up and down sporadically causing the car to want to die out. Sometimes it will run when cold and die and not start back up when hot, other times it won't start at all. Checked a plug from the coil wire to a ground with nothing. Tried a new coil with no luck, got a used good distributor(or so I was told it was good didn't know for sure) it actually got a little better after I installed that but then reverted back. I ohmed out the tfi, then the tfi plug with a light tester, ohmed out the coil, all testing good. I thought maybe the thermal paste on the tfi dried up and that's why it ran when cold but not when hot. Unfortunately the tfi I ohmed out to be good that I put on the distributor to test well now theres no spark so I can't even test that theory.
