Media
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Mustang Cobra Grille Insert Installation - 5.0Resto (87-93 Fox Body)
See our 1993 Cobra Grille Insert Kit here: http://www.latemodelrestoration.com/item/LRS-8200F/1987-93-Mustang-93-Cobra-Grille-Insert-Kit 1987-93 FORD MUSTANG 93 COBRA GRILLE INSERT KIT Brand: 50resto Part # LRS-8200F Fits: Ford Mustang GT & LX Years: 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93) The 5.0Resto 93 Cobra Grille Insert is made from the original Ford Tooling. It includes insert, chrome running pony emblem, hardware and instructions. This is the perfect solution to convert your Fox Body Mustang into a Cobra clone. The Cobra Grille Insert features an opening to allow for improved air flow. This provides engine cooling advantages over the factory bumper that did not have any openings. Add some unique 1993 Cobra styling to your Stang with this grille insert. NOTE: It will need to be painted to match.
Steeda Wins @ June 2014 Homestead Miami Speedway SCCA Race
Dario Orlando, President of Steeda Autosports interview after turning over the drivers seat to Glen Vitale during the final race on Saturday June 14, 2014 at Homestead Miami Speedway. Steeda gives a special thanks to Ford, Nitto, and Tremec.
2011 Shelby GT500 on Dyno
This 2011 Shelby GT500 has more than just some power mods. Steeda Aluminum Radiator Steeda Radiator Support Steeda Panhard Bar Steeda Rear Lower Control Arms Steeda Rear Upper Control Arm Fiske 20" Aluminum Racing Wheels Braille Racing Battery 3.73 Gears
Imported Item
Imported Item
Mustang Lowering Springs Install - SVE Springs & Caster Camber Plates (79-04)
Need more information on how to lower your Mustang? Click here: http://www.latemodelrestoration.com/products/Mustang-Lowering-Spring-Installation-79-04 Adding a set of lowering springs to any Mustang is a must! Not only do you get the benefits of better handling but you also get rid of that 4x4 stance that comes on all factory Mustangs. Not all lowering springs are created the same and that was the case with Tyler's Competition Orange GT. Cheap lowering springs had him avoiding every pot-hole and speed bump he saw in fears of bottoming out. Installing a set of lowering springs on your Stang can be done in your garage and will take first time spring installers less than a couple hours to complete. Add an awesome stance to your Fox Body, SN95 or New Edge Mustang with a set of SVE Lowering Springs. For more information on these springs, click the link above or see the information below. We also carry lowering springs from Eibach, Steeda, Ford Racing & BBK. Don't forget to pick up urethane spring isolators and caster camber plates to finish off your spring install. 1979-04 FORD MUSTANG SVE LOWERING SPRINGS COUPE HATCHBACK Brand: SVE Part #: SVE-5300A Fits: Ford Mustang (with V8) GT, SVT Cobra (93-98), Mach 1, Bullitt Years: 1979 (79) - 1980 (80) - 1981 (81) - 1982 (82) - 1983 (83) - 1984 (84) - 1985 (85) - 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93) - 1994 (94) - 1995 (95) - 1996 (96) - 1997 (97) - 1998 (98) - 1999 (99) - 2000 (00) - 2001 (01) - 2002 (02) - 2003 (03) - 2004 (04) 79-93 5.0L Mustang Coupe and Hatchback (including Cobra) - 1.2" front/1.0" rear drop 94-04 4.6/5.0L Mustang hardtop - 1.5" front/1.5" rear drop 94-98 Cobra hardtop - 1.5" front/1.5" rear drop 03-04 Mach 1 hardtop - 1.1" front/1.0" rear drop 2001 Bullitt hardtop - 1.1" front/1.0" rear drop
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
