Media
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Suspension/Alignment Shop
Getting alignment at Performance Control Center
Mustang Throttle Body Installation - SVE (86-93 5.0L Fox Body)
Get more information on the this Mustang performance throttle body here: http://www.latemodelrestoration.com/item/SVE-TB1501K/SVE-70mm-Throttle-Body-And-EGR-Spacer-50L-Mustang-86-93 Upgrade your puny factory throttle body with a SVE 70mm throttle body kit that includes the TB, correct EGR spacer and all needed gaskets. Not only will it give you a boost in performance but it will also improve the under hood appearance with its polished finish. Watch the video as Jmac shows you how to install a new performance throttle body on your Fox Body Mustang. Part Number# SVE-TB1501K Fits: Ford Mustang 5.0L GT LX Fits the following years: 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93) SVE Throttle Body & EGR Spacer Kit This 1986-1993 Mustang SVE 70mm throttle body and spacer kit is perfect for adding horsepower and torque to your 5.0L motor. By increasing the size of your throttle body and EGR spacer, you get more air flowing into your motor which gives you increased performance! Pick up this kit today and get your Foxbody outrunning the competition. SVE 70mm Throttle Body This 1986-1993 Mustang SVE throttle body is a great way to bring in more air for more power on your 5.0L motor. This throttle body has an opening of 70mm, a huge increase from the 55mm that came stock on these motors. This allows you to bring in as much air as possible to help maximize your performance. Pair it up with a cold air intake and a new intake manifold for serious horsepower gains! SVE 70mm EGR Spacer This is an SVE 70MM EGR spacer for your 1986-1993 Mustang 5.0L. This spacer is needed when replacing your throttle body to ensure proper flow through the throttle body to the intake manifold. It also has coolant line provisions that help in heating your air charge temperature. Includes the EGR gasket and spacer-to-intake gasket.
Imported Item
Imported Item
À vendre GT 2005  67000km
819 575 1370 Guylaine
Imported Item
Imported Item
GT 2005 A1 à vendre 819 575 1370
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
GT500 stripes were the first mod I did. The temporary license is still in the back window!
Imported Item
Imported Item
Bone Stock
Imported Item
Imported Item
My 2005 GT 4.6L 3V. Black with silver stripes
Imported Item
Imported Item
My 2005 GT 4.6L 3V
Imported Item
Imported Item
Stock headlights and fascia
Imported Item
Imported Item
1st day. Brand new.
Imported Item
Imported Item
Boss 302 lower fascia, chin splitter, and deletes
Imported Item
Imported Item
'12 5.0
Imported Item
Imported Item
'12 GT - I'm done with the external mods. It's all about the guts now.
