Media
Frame Ground
Frame Ground
Grinding off paint and primer for ground for audio system.
Frame Ground
Frame Ground
1/0 gauge wire soldered and screwed to frame under car.
Spare Tire Well
Spare Tire Well
Closed Cell Foam lining the spare tire well.
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
XS Power Battery
XS Power Battery
New battery, terminals, and wiring. Also beginning work on the fusing and 1/0 wire for amp power.
Driver's Door Panel
Driver's Door Panel
Stock door panel before modification.
