Media
Rear Seat Bottom Uninstalled
Preparing to add more sound deadening.
Head Unit Area
Head Unit Area
Removed the factory head unit and factory amp.
Door Panel Replacement
The beginning of modifying the door panels. I'm eliminating the saggy map pocket and also creating a sturdier and deeper mount for the door speaker.
XS Power Battery
XS Power Battery
Replacement battery and terminals. Also upgrading factory grounds and power wiring.
Imported Item
Imported Item
Audio - Linear Power Amps
Working on placement for amps for the audio system - new LP2250.
Hatch Cover Panel
Hatch Cover Panel
Panel re-installed after sound deadening.
Spare Tire Area
Spare Tire Area
Applying sound deadening.
Cover Panel for underside of Hatch
Applied sound deadening, additional jute pad, and trunk liner.
Under Side of Hatch
Under Side of Hatch
Spare Tire Area
Spare Tire Area
Passenger Side Door
Passenger Side Door
Sound deadening applied to inner skin.
Passenger Side Door
Passenger Side Door
Applying sound deadening to the outer skin of door.
Passenger Side Door
Passenger Side Door
Door panel removed - before applying sound deadening.
Passenger Side Door Panel
Stock - before any work
Driver's Side Door Panel
Stock Battery
Stock Battery
Stock battery, wires, and terminals before upgrades.
Passenger Side Door
Passenger Side Door
2 layers of closed cell foam applied over entire inner skin - over sound deadening.
Rear
Rear
Rear Seat
Rear Seat
Day Spa 5- July 2013
