Media
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Side Profile
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Mustang Distributor Install
Are you replacing your worn out ignition coil and wires? Or do you have a worn out stock distributor giving you issues? Then you are in need of the Performance Distributors 1986-93 Mustang 5.0L Hot Forged Aluminum Distributor. This drop in ready distributor will ensure you get the most out of your Mustang ignition coil and plug wire upgrade. If you are currently having TFI module issues or have a worn rotor and cap then this makes a great upgrade for your 5.0L Mustang. In the video Jmac walks you through removal of your stock Mustang distributor and shows you how to install the new Mustang Performance Distributors Hot Forged Aluminum Distributor. The 1986-93 Mustang 5.0L Hot Forged Aluminum Distributor features a hot forged aluminum housing, new cap and rotor, includes a Dyna-Mod TFI Module and is compatible with roller cam.
05-09 Mustang Shifter Install - Hurst S197
It's time to improve your 05-09 S197 Mustang's sloppy stock shifter. Replace that worn out stock shifter with an aftermarket Mustang short throw shifter such as Hurst, Barton Industries, Steeda, Pro 5.0 and more available at LatemodelRestoration.com. Don't forget to add a new trick Mustang shift knob to give your Pony that distinctive look. Follow along in the video as Jmac shows you how to install a shifter in your 05-09 Mustang. LatemodelRestoration.com carries short throw shifters for the following models and years
Corsa Sport Axle Back On Mustang GT
Add some amazing sound to your 2013-14 Shelby GT500 with the Corsa axle back kit. Amazing sound isn't all you will get! The high flow design will also free up some extra horsepower in your already super power 5.8L supercharged GT500. The Corsa axle back features twin 4 inch Pro Series polished tips for great looks. The mufflers were designed to produce no interior resonance all while flowing 43% more than the stock mufflers! Want to add the quad tip axle backs to your 13-14 Mustang GT, V6 or Boss 302? No problem! Pick up a 13-14 GT500 Rear Bumper Diffuser/Valance and you can add this look to your Stang! Check out all our Mustang exhaust options at LatemodelRestoration.com
Mustang Sunroof Weatherstrip Install
A leaky sunroof is a major problem and headache! It can ruin your Mustang upholstery, carpet and many other interior components. Lucky for you we carry everything you need to fix your leaky sunroof. In the video Jmac even shows you how to clean out the Mustang Sunroof Drains to ensure you don't have any draining issues for years to come. Pick up all your Mustang sunroof parts from LatemodelRestoration.com and get free shipping on all parts!!!
Mustang Fender Hash Mark Decals - SVE (79-14)
Are you looking for a great way to add some serious eye catching style to your 79-14 Mustang? Pick up a set of SVE Fender Hash Marks today. They are available in multiple different colors including matte black, white, gloss black, grabber blue, silver, red & blue!
Mustang Door Hinge Repair Kit Install - 5.0Resto (79-93)
1983-93 MUSTANG MASTER DOOR HINGE PIN & BUSHING KIT Brand: 5.0Resto Part #: LRS-23204-KIT Fits: Ford Mustang GT, LX & SVT Cobra Years: 1979 (79) - 1980 (80) - 1981 (81) - 1982 (82) - 1983 (83) - 1984 (84) - 1985 (85) - 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93) Got saggy doors on your Fox Body Mustang? No problem! We have a fix for your sagging doors with our 5.0Resto Mustang Door Hinge Pin & Bushing Master Kit. This kit includes steel hinge pins, hinge bushings, hinge retainer pins, hinge rollers and roller pins. Follow along in the video as Jmac shows you exactly how to replace your hinge pins, bushings and roller. Don't forget to pick up a new DOOR CHECK SPRING to finish off your door restoration project!
Cobra Bassani Exhaust System: Headers,Offroad X & Catback
Tony, LatemodelRestoration.com employee, owns an amazing Redfire 2004 SVT Cobra. It features a full Bassani exhaust system: Mid Length Headers, Off-Road X Pipe & Catback. Watch the video and tell us what you think about this awesome Terminator Mustang Exhaust System!
Fox Mustang Tech: How to remove your seats
Removing the seats in your Fox Body Mustang is a key part of many installations which include carpet and upholstery installs. Removal of your seats is actually a simple procedure. Follow along in the video as Jmac show you how to take the seat of Coupe, Hatchback and Convertible Fox Mustangs.
05-09 Mustang Lower Control Arm Install - Front FRPP GT500 Style M-3075-E
Worn out lower control arms on S197 Mustangs are a common reason for pops and other annoying sounds coming from the front suspension. Chances are the bushings and ball joints have worn out. To ease the install on our Mustang we decided to use the ¬Ford Racing GT500 Lower Control Arms ( M3075E ). These control arms include pre-installed performance bushings and ball joint. Having these already installed on the control can cut down drastically on your install time.
Mustang Ignition Switch Install - 5.0Resto (79-93)
1979-93 MUSTANG IGNITION SWITCH Brand: 5.0Resto Part #: LRS-11572A Fits: Ford Mustang GT, LX, SVT Cobra 5.0L & 2.3L Engines Years: 1979 (79) - 1980 (80) - 1981 (81) - 1982 (82) - 1983 (83) - 1984 (84) - 1985 (85) - 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93) Broken Fox Mustang ignition switches are a common problem. They cause some very troublesome issues as they start to ware out - won't start condition, air condition A/C issues or the worst case scenario FIRE. The problems are cased by the crimps that hold the ignition switch together. After years of being in service they get worn out or worse break off.
