00' brake swap
quick question, i am doing a five lug swap with brakes from a 2000 GT i pretty much have all the parts i need i was just wondering if i can use the stock front brake lines off the 2000 and if so what i have to do to adapt them. i know i should buy new stainlees lines, and i will eventually, but i need to save my money for new tires. thanks for the help guys.
daniel
Drivers side bolts up fine, passenger side hose is a smaller fitting, so you will need an adapter. Just take the PS 2000 hose and the Fox hose and get the right adapter to go from the larger hard line to the smaller hose opening. You will probably have to file out the hose mounts to get the end of the hose ot sit flat when you install the retaining clips. I ran the stock 99-04 hoses on my car with the PBR calipers for a couple of years.
Good luck!
