  • SN95 4.6L Mustang Tech
02 gt throwing codes help please
  • Thread starter Thread starter eric428
  • Start date Start date May 7, 2011
E
eric428
  • May 7, 2011
Hello, I took the car for a ride today and got a CEL. I had the car scanned and two codes came up: p1151 bank 2 sensor 1 switch point indicates lean, and p1131 bank 1 sensor 1 switch indicates lean.
I am running a summitt racing off road h-pipe with mil eliminators, cold air intake the rest of the engine is stock any help would be appreciated.
boston2k4
107
  • May 19, 2011
hmm sounds like the 02 Sensors in your manifolds went poop
i pulled this off obdcodes.com
A code P1151 may mean that one or more of the following has happened:
Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit Corrosion or poor mating terminals and wiring
Damaged HO2S Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system:
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam Timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
i would check all red texts areas .. but this is just me
your air intake is after market so make sure everything is tight and didnt wiggle lose on you
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
May 19, 2011
  • May 19, 2011
+1 on above and in addition, focus on things that could affect BOTH banks at the same time. For example, a vacuum leak in the upper intake, MAF problem, or exhaust leak.
IMO, it is less likely to be an O2 sensor problem as it is unlikely to have both O2 sensors fail at the same time.
Also assume that all fuses have been checked.
fast97gt
1,082
north carolina
May 20, 2011
  • May 20, 2011
im gonna say maf, or vaccum leak.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
