  • SN95 4.6L Mustang Tech
02 stock intake
  • Thread starter Thread starter WRXracer
  • Start date Start date Jan 16, 2004
WRXracer
825
  • Jan 16, 2004
im taking off my stock intake from my 02.. this is the one on the engine.. is it worth anything..
keepsbreakin
45
  • Jan 16, 2004
Since it has the aluminum crossover, it is worth something to the '99-early '01 guys. I sold my extra '03 intake (long story) for $100. I suspect you could get at least $50 for it.
C
CuddaWuddaShuda
678
  • Jan 16, 2004
Sure, I would imagine it's worth something to anyone whose trying to put the '99-and-up cylinder heads on an early 4.6L motor. They will need to get that PI intake somehow.
What is the aluminum crossover? I have an '01 (albeit a late production one)and I've never heard of that.
D
DarkHorse164
319
Port Charlotte, FL
Jan 16, 2004
  • Jan 16, 2004
subscribing.....
KaPPaBaLL
1,326
BAYAREA
Jan 16, 2004
  • Jan 16, 2004
you mean the lower intake manifold? why are you selling it? you won't get more than $100 for it.
keepsbreakin
45
  • Jan 18, 2004
The crossover is where the coolant flows thru in the front of the intake, and has the thermostat in it. The 96-early 01's had a plastic crossover that is prone to cracking and leaking. When it leaks it shorts out coils, and can do some damage. The fix is the aluminum piece for coolant to flow thru. It was a TSB on all Crown Vics with 4.6's, and any other 4.6 cars with plastic crossovers that started to leak under warranty. ('96-00 Mustang GT's are effected.) Just one of those things.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
