02 stripped how to get out?
Jaswir
578
Orlando, FL
well can't get one 02 sensor out for anything!
i tried heating it with a toruch
and spraying it blaster stuff to help loosen
now i cant get any wrench on there and vice grips just fall off
tool can i buy to help? or am i going to have cut and drill it out???
You may have to cut it out / grind it out with a dremal or right angle grinder. The O2 nut may also be worthless. So, in that case, cut off (or grind off) the O2 bung, and weld a new one on.
What type of torch? Just Propane? In that case, try MAPP. An Oxy Acy torch should be able to melt the sensor and bung right off! :) Heck, I can cut car frames with mine. :)
i had to use an oxy cetanline (sp?) torch and we had to get it glowing orange i mean bright orange, then we put th wrench on and busted it off... ur wrench wont fit now so maybe you will cut and drill and tap
Once I heated it up, put the H-pipe (well the sensor) in a vice and unscrewed with the H-pipe (plenty of leverage). That was a last effort though - even the freaking air gun wouldn't do anything with that sucker.
Doesn't heat make things expand? I would think on something threaded, heating it up would make it harder to take out? Of course, science never was my best subject, so I could be totally wrong here.
