03 Airbag module...were is it??
whyask
735
Sacramento
OK guys I keep getting an airbag light, My horn dosnt work, cruise control dosnt work, so i think its my clock spring, BUT i had a flamming river steering shaft put in and I think they also forgot to connect the airbag module, I HAVE NO IDEA WHERE IT IS ! Any pics of advice thanks guys !!!
:SNSign:
Well, if your had a shaft installed I would say its the clock spring. The wheel was turned when the shaft was disconnected.
to answer your Q now, the air bag module is located uner the radio. If you pull back the carpet you will see the 8 mm bolts and it will come right out.
Some clock springs you can reset. Pull the wheel off and read the directions on the sticker on the clockspring. It should say.....Turn clockwise 2 turns, then counter clockwise 1/2 a turn.....or something like that.
I had one with an AIRBAG light on, and I did what the clockspring said....BOOM, no more AIRBAG light, and my SRS system worked properly.
