03 build
woj1
minnesota
hello looking for advice and ideas on an 03 gt convertible build have a few mods already cold air,x and exhaust, 410s and some suspension looking to add stage 2 cams and a 78mm throttle body want to know what would be a good injector upgrade with this setup
Changing the cams or injectors will require a new tune to properly run. I'd upgrade the throttle body and plenum. Then when your ready to change out the cams, swap for ford performance injectors only. Then take it to get tuned. What other plans do you have for it aside from these. Just asking cause I started upgrades and couldn't stop only to have the rings fail, not being able to support the horsepower.
