yes, they 96-98 cobras used the Teksid block that was made in Italy. Teksid was a supplier to Ferrari. they are cast from SAE 319 modified aluminum alloy and weigh a little more than 85lbs. in 99, the blocks different slightly, mostly from some changes in the main cap detail and the side main bolts. in 2001, they switched to a different block known as the WAP (Windsor Aluminum Plant) block. it had different oil drainback holes that kept oil away from the crank as much as possible. the WAP blocks look stronger because there is increased outside webbing.
