- Jun 2, 2005
- 143
- 0
- 0
i got a 2.76 upper right now with 13/14 psi. boost. i was supposed to get a 6lb lower pulley ,but got a 9.0 inch or 8lb pulley,,my eaton off getting ported right now.how much boost will i have appx.? if i dont return it , cause iam getting the run around with rpm outlet again .i had a credit there if you remember correct.of $225.00 thats the only reason i order from them .dont use rpmoutlet for anything. so whats the boost?
! Even if you went with a 6 lb lower the combo would potentially make 18 psi and blower RPM would be 21,431.
